After looking about on the internet, to my shock there is nothing about turning the power up on a Uniden Uniace 300...
Plenty of Cobra's and that but I can't find anything inside mine that looks like those...
[/URL]
[/URL]
Dragonfly wrote:Its most likely been peaked a hundred times over the last 25 years but what the hell .
The Horse shoe,s are clearly marked the front one being DEV = Mic Gain which I can see is already fully up . SM=Recived needle position . SQ = Squelch Position . . The two at the back will be Low Power switch adjust at the left side and at the middle rear will be key up needle position . If you didn't notice these then you shouldn't really be twideling about inside as you will probably mess the radio up.
Ohh right, I see! ThanksDragonfly wrote:If the signal meter is showing correct poundage form your mates then you don't need to adjust the SM pot and when you key up if the needle goes to 4 wat or slightly more then the TX horse shoe wont need adjusting , If the needle hits the end when you key up then you could adjust back a little the TX horse shoe .
