very low Audio on TTi TCB550N
billybobbybutton
Hi Just installed my new TTi TCB550N into my MX5 and powered the unit via a Mini Blade fuse adapter in a nearby fuse box, (was directed to use this method from another MX5 user),. Connected the Antenna and turned the unit on and got very low Audio via internal speaker, I Turned the fuse round in the holder (Just in case) but still very low audio, Anyone else come across this problem?
Thanks Bill
billybobbybutton
Update, Ran an a Power feed direct from the battery, made no difference, spoke to Thunderpole and the very kind Colin there talked me though some tests , it turns out there is a set fault, so just sorting out the RMA,
PolishNicholas
We have a TTi 771 and the audio is very good (in WV sharan).
:D
glad you are sorted now
