antron99
padster
CB Handle: night owl
what you reckon will it improve tansmission and reception :D
what antenna are you currantly using .
yes but you have to put the firestick replacement on top to lower the field
padster
Dragonfly wrote:what antenna are you currantly using .
1/2 WAVE at minute :D :D :D
Should give an s point or 2 improvement over a half wave gp , Best things about the A99 is that they are compact , stay straight and generally last for donkeys years .
padster
Dragonfly wrote:Should give an s point or 2 improvement over a half wave gp , Best things about the A99 is that they are compact , stay straight and generally last for donkeys years .
class cheeers dude ;-) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
matchbox
I am told that the Antron99 will bleed noticeably if not erected high enough. Gonna whack mine on the gable side as it is just under 20ft and legal.
