Quiet microphone.
I have had the rig set up and working a couple of days now, but only got my first response today from a trucker at junction 1 on the M18 motorway about 1 mile down the road from me. He reported that my signal was very strong and clear audio. However he said I was very quiet. I had the mic. about 4" from my mouth and was speaking in my normal (which is not quiet
) voice. I put the mic. closer to my mouth and spoke louder, which he said was slightly better, but still quiet. He said somthing in the set needed turning up, but I can`t remember what he said. As the set is brand new I suppose I should call in at Thunderpole with it, but thats a 200 mile round trip
. Any help or advice would be welcome.
David.
even if the set is quite provided the audio on tx is clear then you will be heard if you whant to make it louder then add and echo/power mic to the set other wise pm me and ill sort it out as your comeing up north later
Providing people can hear me OK I am not bothered about it being loud and I don`t like echo mics. anyway. Trouble is getting people to answer you, so that I can get a general opinion of whether it`s OK or not.
David.
I`ve just been talking to two guys one about 8 mile away and one about 6 mile away from me. They both confirm that I am quiet, but it could be possibly the fact that I am at the side of my house, which is in the middle of a stone terrace. However like I explained when I have been mobile, I can`t get anybody to answer
David.
breaker 19
- Official CB Nut
stupidly have you got a pre-amp mic with volume control on mic and have you tried the battery in the back
No it`s just a standard mic. no battries
I think I might have found the problem though. When I installed the radio and mounted the antena in the center of the roof, it had been raining. I wiped the area where the mag mount was going and positioned it. When I checked the swr it was 1.1. However we havn`t had any rain for a few days now so the car is dry and when I checked the swr today it was 2.5 I have moved the antena to the back of the roof and the swr dropped to 1.8 to 2.1. I loosened the grub screw and raised the whip about 3mm and the reading was above 2 through the channels. So I shortened the whip about 3mm and replaced it. The swr then was 1.7 to 1.9 over the range. So I took another 3mm off hoping it would drop further, but it didn`t it stayed at 1.7 to 1.9. So I have left it at that, but I`m not happy with it. So I`m assuming the good swr was because the car was wet.
This is new position.
David.
orbiters pick up reflection of the roof so moving it back has reduced the reflection and at tha kind of swr you would be as well leaving it alone now
you will find out its slightly directional with best signal going across the greatest length of ground plane
