What do I need?
LJW
Hi all, I'm looking into getting a CB Radio but unsure what I would require, so any help appreciated!
As a bit of an intro as to why I need one, I work around Scotland and quite often in the back and beyond areas where phone signal is weak to non existent, quite often up in the hills off the paved roads. As its coming into winter again its got me concerned that if I get stuck or break down etc, I'm pretty screwed!
Now I'm not sure if a CB Radio would be the right answer as I'm not sure of the range etc, but its all I know of without your expert advice.
So in a nutshell, would CB Radio be the right solution, and if so what would be the right equipment to get?
Thanks in advance.
(p.s. It will be vehicle mounted 12V)
basic cb thunderpole T800 or T1000 WITH most expensive cb antenna Wilson1000 would seem to be the answer
but whatever you do dont go for a cheap antenna
