Could you please show me the wiring config for power supply on my K40 mike Thank you ie : from power supply using diode/resistor as this is not very clear on the instructions
K40 Mike Wiring
Take the tx wire off the mic socket.
Solder a 1n4001 diode to the pin you took the wire from with the cathode (line) to the pin and solder the tx wire to the other side (anode) of the diode.
Then solder a 1k resistor to the mic pin/cathode of the diode and feed it with 12 volts.
Dave
Dave
