Hi, newbie from Surrey
Blue Lagoon 22
CB Handle: Blue Lagoon
Hello everyone,
Complete newbie here from Surrey.
Hopefully will soon be fitting my CB set up onto my Mitsubishi Shogun 4x4. :)
Anybody else with a car set up in Surrey? .....I might need to pick your brains! 8-)
Help, I'm still learning
Hi and welcome to the forum :)
Andy.
Hair Bear
Hi, what are your plans for fitting?
Blue Lagoon 22
andy@thunderpole.co.uk wrote: ↑Wed May 18, 2022 11:41 am Hi and welcome to the forum :)
Andy.
Hi Andy, thank you for your welcome message
Blue Lagoon 22
Hair Bear wrote: ↑Mon Jun 13, 2022 8:12 pm Hi, what are your plans for fitting?
I've got a T-600 in my Mitsubishi Shogun.
I've routed coax up the inside of A pillar, along the inside of headlining and drilled a hole in rear section of roof for antenna. Mini Springer antenna sitting on a black dome roof mount.
Hair Bear
I'm across in east Hampshire, (Aldershot).
My opinion? You got it right. Both my cars are set up that way each using a smallish center loaded antenna from a 'twin trucker' pair. It's the best way to get a decent earth and consistent swr, although a bit of a pita when you find yourself in the lane for the multi storey and have to do a bit of climbing to take it off. Is this for offroading or general use?
VW Touran install
P38
Blue Lagoon 22
Nice photos, looks good :)
I only use my Shogun for road use plus the odd visit to car shows.
I've had my antenna hit (at low speed) a few car park height barriers. As you say pita jumping out all the time.
My antenna needs shortening due to high swr. What's the best way to trim it?.....Cut a bit from the top tip or cut a piece off from the bottom where it sits in where the adjusting screw is? I cant lower it anymore it's at its lowest adjustment.
Cheers for any advice
Blue Lagoon 22
Forgot to say. My antenna is a mini Springer stinger.
