Hello all and it is lovely to be a part of this forum.
I know my question will have been asked lots of times but looking at posting subject lines, I just can't find one to look at, so forgive me for starting a new conversation thread.
I would like to buy a CB rig for my home and wondered if there is a most recommended, basic rig for a newbie with no technical experience and also, do I need to connect the radio to an external aerial or does it come with an attached aerial and no need to think about wiring?
Essentially, I would love a CB radio at home to chat to people and don't know where to start.
Any pointers or tips would be absolutely wonderful.
Thank you for reading this.
Medusa
New to CB and looking for advice
Hi and welcome.
Oh wow - a can of worms complete with a ring-pull for easy opening!
Have you had access to a setup before? Do you know if there is much suitable activity in your area?
There are four basic components to a set up, A radio, microphone, coax (antenna cable) and the antenna itself. If you are looking for something small and unobtrusive, to fit up under a shelf for example, most if not all vehicle type rigs can be used. It would require to run on a small mains power supply. There are dedicated home base rigs available that plug direct to the mains. These tend to be of larger construction. An internet search of pictures will give you an idea. Some of the base radios from the 1980s can be a statement in themselves. The actual output performance of the radios themselves will be very similar but the bigger radios almost always have a better audio on receive, dependent of course on the quality of the signal being received.
A standard microphone will be supplied with a new rig, not so much with second hand rigs but easily available separately and upgradeable if you wish.
You will need a separate antenna. General rule of thumb is the bigger, the better. Not always true but it depends where you intend to site it. An 18 footer on a 20 foot pole in the garden will work magnitudes better than a 4 foot in the loft!
One you have an idea of what rig, where in the house you want to install it, and where your ideal antenna will go, you need to consider the route of the coax cable to connect the two together.
Have a think and come back to us, we'll help where we can.
One person in ten understands binary. The other one doesn't.
Hi there and thank you so much for your reply.
Firstly, I love your tag line, I bet lots of people ask you what it means lol.
In terms of siting, I want it in my bedroom, bedside table so size doesn’t matter. It sounds like I will need an aerial outside connected by a coax cable… is that correct? If so, it may not be a huge problem as I already have a coax point in my bedroom so could possibly chase through that.
Is there a way to find out how active cb chat is in my area before I buy some kit and find out no one is ever there?
Thanks again for your help.
Medusa x
Medusa x
Is there anybody there??? That's the $64,000 question. in the 80's this was your local social media.
Can you give a rough idea of your location?
The obvious way is to get all set up and listen. Not helpful. An enquiry on your local faceplant might give you some pointers. A search online to see if there is a local club perhaps? Search to see if there is a local shop or supplier? Naturally they will tell you whatever they think will sell gear but the fact the shop is there may suggest a local-ish demand for kit. Is there anyone you had in mind to be in touch with - and if so how far away?
You would need an aerial out side for best use. The type of coax you use is important. Be aware that the coax point in your room will have a different coax cable 'rating' and be suitable only for UHF /VHF tv and broadcast radio, not 27mHz CB. If you were thinking of running the CB coax along the same route as the tv coax you run a good risk of causing a lot of interference on the TV.
As for the radio itself, my thoughts would be Harrier HQ, Uniden 3000, or Harvard H407, in my experience all good solid 'old school' units and mains powered. Going more modern there is the Team 3000, there are almost certainly others but search some pictures, there may even be videos of them in use. All can be fitted with hand mic or desk mic. Consider what you may be more comfortable with.
Over to you...
Over to you...
