Hi to here, I recently got a
Sigma Red Devil
1/4 wave base loaded mobile antenna
Power Handling 500 watts
Length 1.89m
Coil length 460mm
Coil diameter 22 mm
Impedance 50 Ohms
Frequency 26-28 Mhz (full 80 channel coverage)
SWR 1:1.5
Fitting 3/8 UNF
Whip: 17/7 ph Stainless Steel
The issue I have is the mount, I have a mag mount Thunderpole Mag Mount | 5" Large CB that was given to me a while back, but i just saw that it says Note: Mag Mount is not suitable for antennas longer than 160cm. so I was wanting to know what mount will work for this antenna, I do prefer a mag mount, also it's for a home not a car.
thank you.
