kl203 amp
bassy 1019
how do you connect these to the car? also what size power cable do you use? connect to battery or cig plug thanks 4 your help, matt
matt
bassy 1019
wot no answers yet, anybody?
matt
Sparky
Need more information to be able to help Matt, ie what is its input load in amps, should be on a label some ware
Sparky
I get confused if there is more than two wires
use a home extension cable twin core from any do it yourself place and wire stright to the battery make sure antenna is 1.5 or less and you shoud be ok
