Regulations?
randombod
CB Handle: randombod
is there a given regulation length the antenna can be before you need planning permission etc? what are the general rules and regs for home rigs
most councils seem to not bother about cb antenna as thy could be opening a can of worms as far as i know anything over the height of the chimmney needs planning permission so all tv antennas that are above the chimmney should have planning permission .i think that they tend to say unless there is a complaint then let it go
randombod
stampman wrote:most councils seem to not bother about cb antenna as thy could be opening a can of worms as far as i know anything over the height of the chimmney needs planning permission so all tv antennas that are above the chimmney should have planning permission .i think that they tend to say unless there is a complaint then let it go
good good now im deffo interested in home rigs :D what is the range of them things?
Basilsparents
20 miles with a nice setup and good conditions... :P
(Oh yes, I still log on, I'm not dead!)
randombod
Basilsparents wrote:20 miles with a nice setup and good conditions... :P
sounds good to me .... just as well i was about to post a request to see where i send the flowers too
depends on height grass cutter is 700ft up on a hillside and he can do 100-120 miles on a good day
:D :D :D :D :D
randombod
stampman wrote:depends on height grass cutter is 700ft up on a hillside and he can do 100-120 miles on a good day
:D :D :D :D :D
i am not that lucky however i am 2 miles from the a1 so if i dont pick anything up im suffed...
plumb bob
Heard a guy today with a silver rod type antenna, and I think 50 watts, I was mobile and he was 20 miles away, although he couldn't hear me ( obviously)
I later had a brief contact with another mobile and he lost me at about 1 km, which I thought waspretty poor.
It's all about the MONEY
yup 1k is rubbish but if your swr and set up are ok then its his problem
:D :D :D :D :D :D :D :D
