question??
- ellitanthalas
- Official CB Nut
- Contact:
Oh yes indeed!!
I'm still a newbie myself, so I imagine you'll get more detailed info from one of the other guys, but as a basis;
You need a Power Supply Unit (PSU).
Oddly enough, Thunderpole sell a range of decent ones, starting from about £30.
The PSU converts the 240V mains power into 12V, which is what the CB radio requires. You'll need to know what kind of power lead connectors your radio has, but from what I understand most will have either a pair of bare wires or a cigar lighter plug, like what you'd normally plug into a car.
The basic PSUs will have a pair of screw-caps, where you unscrew the cap to reveal a screw thread with a hole in the shaft.
You trim off a bit of the plastic coating on your Radio's power wires, thread the bare wire through the hole and then wrap it round the screw thread a bit before re-attactching the screw cap. The wires should be red and black, with corresponding coloured caps on the PSU.
Alternatively, some PSUs also have the cigar lighter type socket, in which case you just plug the radio in using that plug. Mine is one of these.
Have a look here;
http://www.thunderpole.co.uk/power_supp ... andard.htm
From there, you just whack a suitable length of Coax cable from the radio to your external antenna, SWR it in and away you go.
Hope that helps,
Woody.
Have a look here;
Hope that helps,
Woody.
