And now I've come crawling back for some CB advice, as I'm not as up to speed with the old CB as you guys
My next mission, to fit a CB into my rather battered dinghy. I'm not a mobile phone friendly chap, and it makes much more sense to use my Midland 42 (handheld) to keep in touch with the car (which is parked on the shore with the magmount and mobile rig) than to waste expensive phone calls.
The Midland is going to be in one of those waterproof radio bags, but I recognise that for any type of real performance I'm going to need an external aerial. I can mount it a way up the mast, which I believe is aluminium.
However, it can't be too long an aerial: one metre I'd say is about right, and more importantly, I need it to survive being occasionally dunked in the salt water... tall order I know, and I'm aware that this sort of treatment will quickly enough destroy an aerial. Can anyone recommend an antennae?
Or should I just keep the rubber duck attached to my radio? Over water I see no reason why this shouldn't be reasonably effective also.
Just wanted your thoughts on this
