Dinghy Installation
Basilsparents
Hey guys, believe it or not I'm not dead, I check this forum a couple of times a day :P
And now I've come crawling back for some CB advice, as I'm not as up to speed with the old CB as you guys :?
My next mission, to fit a CB into my rather battered dinghy. I'm not a mobile phone friendly chap, and it makes much more sense to use my Midland 42 (handheld) to keep in touch with the car (which is parked on the shore with the magmount and mobile rig) than to waste expensive phone calls.
The Midland is going to be in one of those waterproof radio bags, but I recognise that for any type of real performance I'm going to need an external aerial. I can mount it a way up the mast, which I believe is aluminium.
However, it can't be too long an aerial: one metre I'd say is about right, and more importantly, I need it to survive being occasionally dunked in the salt water... tall order I know, and I'm aware that this sort of treatment will quickly enough destroy an aerial. Can anyone recommend an antennae?
Or should I just keep the rubber duck attached to my radio? Over water I see no reason why this shouldn't be reasonably effective also.
Just wanted your thoughts on this :P
they do make a marine cb antenna ask colin about it
:D :D :D :D :D :D :D :D
I would say this would do the job quite nicely... http://www.thunderpole.co.uk/excalibur.htm
It is about a metre long and doesn't need a ground plane, it just needs a set length of cable to work effectively.
Basilsparents
Haha, I have one of those purchased from Thunderpole some years ago here at home!
Do you think it will waterproof up alright? White grease, sealant and a little fibreglass sort it out? Thanks for the advice, Andy :) :P
Should be fine, we've sold quite a few of those for boats.
heard a rumor that some people use them as depth gauges as well
