get in there
killer cam
CB Handle: killer cam
iv just ordered my new rig and a99
now on the a99 to adjust the swr you have two rings correct #?
FISH
HAVE FUN. 8) 8) 8) 8)
26 TANGO MIKE 501
killer cam
i will lol
oldskooldaze
killer cam wrote:iv just ordered my new rig and a99
They should be factory set :lol:
disgwylfa
CB Handle: 186-TM-555
They are factory set to MID BAND. The optimum Ch. is Ch.20 Mid Block (27.205Mhz)
If you're going to spend most of your time on UK FM (27.78125 etc) or up on the High Band (27.555 etc) you'll improve your SWR by winding the rings UP a few turns.
. . . "Cherokee"
mpcapri
Good luck Killer Cam =D>
Let us know how it goes
Photos of Antron 99 tuning rings (mine are wound right to the top but I also have a Firestick on top #-o )
Zoom Zoom Zoom
Mart
BEER IS FOR LIFE,NOT JUST FOR CHRISTMAS!
26-TM-1969 - Red Squirrel - Spinney Hill - mpcapri - more aliases than what's his name
oldskooldaze
Mine are the same mart :shock:
killer cam
i will lol
HI CAM THEY SHOULD BE PRE SET IVE NEVER HAD TO MESS WITH ANY OF MINE AT ALL BUT TRY YOUR SWR AND TAKE IT FROM THERE
BUT USE A GOOD STRONG TAPE FOR THE JOINTS ...GOOD LUCK MATE AND LET US KNOW HOW YOU GET ON :D *King*
killer cam
porky what type of tape elatrical tape
mpcapri
oldskooldaze wrote:Mine are the same mart :shock:
Don’t know why perhaps we had the same batch, I just got a better swr when the rings are at the top (both with and without the fireup top section) UK block. Also got a standard silver rod from Thunderpole, set that up with their markings on the aerial and that was absolutely spot on =D> still got to work on the sirio 827's swr but thats a pain to work with :roll:
killer cam wrote:porky what type of tape elatrical tape
hi cam well thats what i used and put it around the joints *King*
killer cam
ok i will buy a roll tomoz
marsh phantom
CB Handle: Marsh Phantom
my a99 at home has a high swr still, the rings need putting up,
and the antron i use for static mobile operation the rings are at the top as i get the best swr there
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
mpcapri
marsh phantom wrote:my a99 at home has a high swr still, the rings need putting up,
Just checked mine again :shock: running standard 4 watts (channel 20) and it’s 1.2
Also checked the same setup but using a standard silver rod and the needle doesn’t even lift when you key up, so presume that’s the perfect swr – push 30 watts into it, calibrate it and the needle just moves. 8-[
Mart
