iv just ordered my new rig and a99
now on the a99 to adjust the swr you have two rings correct #?
get in there
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
- killer cam
i will lol
oldskooldaze
- Good Buddy
They should be factory setkiller cam wrote:iv just ordered my new rig and a99
They are factory set to MID BAND. The optimum Ch. is Ch.20 Mid Block (27.205Mhz)
If you're going to spend most of your time on UK FM (27.78125 etc) or up on the High Band (27.555 etc) you'll improve your SWR by winding the rings UP a few turns.
. . . "Cherokee"
. . . "Cherokee"
Good luck Killer Cam =D>
Let us know how it goes
Photos of Antron 99 tuning rings (mine are wound right to the top but I also have a Firestick on top
Zoom Zoom Zoom
Mart
Zoom Zoom Zoom
Mart
BEER IS FOR LIFE,NOT JUST FOR CHRISTMAS!
26-TM-1969 - Red Squirrel - Spinney Hill - mpcapri - more aliases than what's his name
oldskooldaze
- Good Buddy
Mine are the same mart
- killer cam
i will lol
- porky.69
HI CAM THEY SHOULD BE PRE SET IVE NEVER HAD TO MESS WITH ANY OF MINE AT ALL BUT TRY YOUR SWR AND TAKE IT FROM THERE
BUT USE A GOOD STRONG TAPE FOR THE JOINTS ...GOOD LUCK MATE AND LET US KNOW HOW YOU GET ON
- killer cam
porky what type of tape elatrical tape
Don’t know why perhaps we had the same batch, I just got a better swr when the rings are at the top (both with and without the fireup top section) UK block. Also got a standard silver rod from Thunderpole, set that up with their markings on the aerial and that was absolutely spot on =D> still got to work on the sirio 827's swr but thats a pain to work witholdskooldaze wrote:Mine are the same mart
- killer cam
ok i will buy a roll tomoz
- marsh phantom
- Motor Mouth!
- CB Handle: Marsh Phantom
my a99 at home has a high swr still, the rings need putting up,
and the antron i use for static mobile operation the rings are at the top as i get the best swr there
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Just checked mine againmarsh phantom wrote:my a99 at home has a high swr still, the rings need putting up,
Also checked the same setup but using a standard silver rod and the needle doesn’t even lift when you key up, so presume that’s the perfect swr – push 30 watts into it, calibrate it and the needle just moves.
Mart
