Hi all, i have just bought a Wouxun dual band radio. It covers 2 meter and 70 cm.
I have a set of mitex runing in the 449 mhz band and i have tuned it into them. now im receiving but its not transmitting to the mitex. however the green light on the mitex is comming on when i transmit but nothing is heard. as i said i am receiving from the mitex clearly. Any ideas pls.
Wouxun 2 m 7 cm dual band
- andy@thunderpole.co.uk
- Site Admin
- Contact:
You will need to have the right CTCSS or DCS tone set as well as the frequency to open the squelch.
Donga
- Official CB Nut
- CB Handle: Rockape
Got them speaking. if you note the Mitex frequencies they are just 3 but has a possible 15 less the scan channel.
so 1-3 end in ctcss setting 65.0 then 4-6 end in i think it was 145 something etc.
Trouble im having is when i go to channel 4 it overwrites channel 1.
Im obviously not using the software correctly as i dont know how to create channels in the memory.
Has anyone got one of these radios who can set a few examples so i can follow to get a grip of it pls.
