Tristar 777
robpxr3
Hello All
Well i've acquired a Tristar 777, been having a read up about them and how they can be 'expanded' or 'empromed', is it obvious if this has been done ?
If it has should it pick up UK40 ??
I did take the oppurtunity of lifting the top off and there is some multi coloured banding attached to a separate cicuit board with a 'PLL02' chip.
I'm no electronics engineer but it does look like a retro fit, especially as the separate circuit board has double sided foam on the rear !
I'm hoping some of the more knowledgable on the forum may have a clue ??
Thanks in advance !
Rob
that is your eprom expansion
Yes you'll probably find it is wired to a switch on the front panel, and this will allow you to switch to the UK channels.
robpxr3
Ah brill thanks guys, just need to work out which switch it could be- presumably follow the wires from the chip !!
sound good to me if you had a frequency counter the the job is simple's
Yes you will find that the wires should lead to one of the swiches on the front (or maybe a new one added to the back?)
Then if you don't have a frequency counter, maybe another multiband rig closeby to test which block is which.
robpxr3
Yep i need another rig to test it, but i think i've sussed it- i reckon it's the CB/PA switch, as a few of the wires from the chip go to that- switched it to PA and on the mid block channel setting and i could hear some germans having a chat! Switched to CB and the signal etc was different so i reckon the CB setting is UK40! At least it's receiving something, not bad for a mini Excalibur aerial on the chimney :D
nearly ready to rock and roll
robpxr3
All seems to be well so far, definately picking up the UK40 ok, however to get clear mod on FM when it's receiving the rotary knob marked 'fine' needs to be about 3/4's of the way round, i guess this is normal to need a bit of fine tuning ?
yup just bring the signal in most adapted set's need to do this
robpxr3
Well i actually managed to talk to someone on the Tristar yesterday evening during some skip, got a copy into South Wales !!
However, it was commented by the guy i was talking to that the modulation on the Tristar is horrible so i sent the gf up the road with a handset to listen to my voice to confirm -
Sounds like it's well 'off frequency'- best way i can describe it. Tried fiddling with the knobs but i reckon it must need some sort of tweaking inside, as the mod on my other rig is spot on ??
could be the mic
robpxr3
Did think that but it's brand new and wired for a Cybernet - tried another but still the same!
check with freq counter to make sure its on freq when txing
good luck with it mate, a good radio in there day :)
