Well i've acquired a Tristar 777, been having a read up about them and how they can be 'expanded' or 'empromed', is it obvious if this has been done ?
If it has should it pick up UK40 ??
I did take the oppurtunity of lifting the top off and there is some multi coloured banding attached to a separate cicuit board with a 'PLL02' chip.
I'm no electronics engineer but it does look like a retro fit, especially as the separate circuit board has double sided foam on the rear !
I'm hoping some of the more knowledgable on the forum may have a clue ??
Thanks in advance !
Rob
