harrier cb-x mic or equivalent ?
thanks for that but .......... how ?
my cb-x seems to be functioning fine, i can receive ok, swr ok, but when i transmit, the other person can hear the mic 'click' , my power meter goes over ok , but he can't hear my voice
i think it's the 'big round thing' inside the mic that's given up the ghost.........it's got a vibration membrane & a sealed metal round unit......i'm not a techy !
so.....will any 4 pin mic work, if not, what do i need to do ? thanks again in advance for help the noobs out there
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
Give thunderpole a ring they can probably make one up with the correct wiring for you, wiring differs on radios
mic came super quick on saturday, tried it in my truck today........same prob.....
quess i need a new radio
i know the antenna is important, but as i drive an 8 wheel tipper, i do a bit of quarry & off roading........low trees & stuff getting in the way. does this mean i have to have a springer on top to take the punishiment or is there another way to do it to have the best antenna setup possible ?
is a springer a springer, do they vary in quality & power ?
i better do a post on the antenna forum as well
