back from hols & ready to go
the story so far ?! ......... (please see my other threads)
still have the harrier cbx which i think still works
bought a grandstand bluebird which i think does work
& after a little win on the donkeys ...... & a few celebratory shandy's i did purchase a president lincoln off that 'e' site
so, the plan is to get set up in my truck with the harrier or the bluebird & the lincoln as a home base
going to buy a new springer for the truck & see if that cures it
buy what you guys suggest for the lincoln at home .......i am about a meter above sea level
the lincoln will be upstairs ........... what antenna do you guys suggest to make the best use of the lincoln ?
i'll start threads in the correct section......truck cb with grandstand or harrier & new springer .........homebase antenna for the president lincoln
thanks in anticipation for all your help =D>
