I brought my Rotel up from the garage after a 11 year stay to find it surprisingly working. Now, however I've discovered there is no modulation when the mic is keyed. Everything else seems to work fine.
I've taken the cover off to inspect the mic wiring & all seems as it should with no broken solder or dampness. Any ideas folks?
Rotel RVC240 modulation problems
- andy@thunderpole.co.uk
- Site Admin
After a long spell in a garage dust and corrosion normally get into switches and controls, so could be clear/norm switch on the front, or the mic gain control...
Or could even be internal deviation pot.
