i've recently come back to CB radio after a long long time off air.
My current living arrangement doesn't really allow me to put the ideal antenna on the house where i live, so i have started with using my Sirio Mobile whip mounted on a 10ft mast using the mounting brackets and radial kit that i have attached pictures of here: Combing these with my old rig...a Harvard H-407 (which i believe is peaked to around 20watts)...i am getting a very high SWR reading across all 40 channels.
Q1: do you think that running an earth cable from the mounting bracket down to an earthing-rod in the ground outside my house will help with this? i am reading here and there that this could help my SWR dramatically.
Q2: i also get around 3 pounds of constant noise when just receiving which i'm sure is ruining my reception of those marginal stations....could this also be down to the lack of antenna ground? OR is that probably down to the fact that since i last had a home setup WIFI has been invented?
I am getting out....at least 13 miles as-the-crow-flies via a rig-check the other night, but really don't want to have extented TX in case i damage the radio.
Friendly advice welcomed here, or pretty much 24/7 via ch19 if you think i can hear you.
Thanks in advance...
