Unable to transmit
Longbridge
I have a tti tcb-770 that I have had for about 8 months the setup has been working up until last week when I realised that I was unable to transmit, when I try to transmit my signal meter goes up but other users cannot hear me (I can recieve fine). I tested with my mates CB and when I transmit his signal meter goes up but can't hear me. I have also noticed that one of the channel keys on the mic has also stopped working.
Does this sound like a problem with the mic or the set itself?
David.
broken wires in mic cb end most likely
:D :D :D :D :D
EarthWormJim
Hi i got the 880 the up channel button on my mic plays up sometimes does anyone know if its a common problem with these rigs?
Jim,
2H4OW
M3OJP
not enough sold to raise a common problem yet ring colin and have a quick word he should be able to tell you he has his finger on the pulse
Sparky
Have had similar problem with my TTi 770, mike button would not work a short while after I parked my van and switched the engine off, I traced the fault and found it to be a problem with the set it appears to be sensitive to the drop in supply voltage, although it was still within the makers recommendations.
I add that Thunderpole confirmed this and repaired the mike free of charge; I’ve had no problem since :lol:
Sparky
I get confused if there is more than two wires
cant see how a mic repair could fix a voltage problem
Its a resistor change, to a lower value. It seems the one fitted on the up button is too high in value so doesnt let enough voltage through to change the channels.
Fault is only apparent when supply voltage drops to approx 12.3 volts.
you lives and learns den thought you where on holiday or getting over the weekend out
:D :D :D :D :D
Longbridge
So would you recommend I get a replacement mic?
David.
David: Yes that is the first thing I would try.
Stampman: Gonna take a while to get over the weekend, glad its only once a year. Will put some snaps in the gallery when I get a spare hour! haha :lol:
thought rude photos were not allowed
:oops: :shock: :shock: :shock: :shock:
EarthWormJim
thanks chaps much appriciated will have to have a word with my mate steve. 8)
Jim,
2H4OW
M3OJP
How about this for a dirty photo...
so colin was selling mud baths to the ladies for £5 a time as that was all he could afford ? :D :D :D :D :D :D
EarthWormJim
oooohhh er mrs that is dirty lol :lol:
Jim,
2H4OW
M3OJP
