hi im scoobyvandriver im buying a cb for the car but i need to transfer it to my coach what do you recommend i buy
need to plug into a cigar lighter socket no good a mechanical stuff just need to plug in and play
newbie
scoobyvandriver
thanks i bought a midland98plus got in the car works fine
Stampman are you sure? I know the 48excell is dual voltage but I have a Midland 78+ and AFAIK It will only run off 12v.stampman wrote:midland 78+ or 48excell as both can run off 24volts or 12 volts
Maybe I should hook up 2 batters and find out what will happen?
HARRIER - CBX ---quality CB built on the famous Cyberrnet 134AOX board.
'Breaker One-Nine, what's your 20? I Hammer'd Down on the A3
I eyeballed a Kojak with a Kodak so I pulled in behind a Suicide Jockey.'
