newbie
scoobyvandriver
hi im scoobyvandriver im buying a cb for the car but i need to transfer it to my coach what do you recommend i buy
need to plug into a cigar lighter socket no good a mechanical stuff just need to plug in and play
midland 78+ or 48excell as both can run off 24volts or 12 volts
:D :D :D :D :D :D :D :D
scoobyvandriver
thanks i bought a midland98plus got in the car works fine :D
dont use in the coach without checking the voltage of the cigerette lighter as i am sure it will be 24 volts
Daedalus
stampman wrote:midland 78+ or 48excell as both can run off 24volts or 12 volts
Stampman are you sure? I know the 48excell is dual voltage but I have a Midland 78+ and AFAIK It will only run off 12v.
Maybe I should hook up 2 batters and find out what will happen? 8-[
HARRIER - CBX ---quality CB built on the famous Cyberrnet 134AOX board.
'Breaker One-Nine, what's your 20? I Hammer'd Down on the A3
I eyeballed a Kojak with a Kodak so I pulled in behind a Suicide Jockey.'
SORRY SORRY SORRY
must have been having a super bad day or been distracted the 78 is NOT NOT NOT a 24 volt set many apoligies hope its still ok
8-[ 8-[ 8-[ 8-[ 8-[ :mrgreen: :mrgreen: :mrgreen:
