Homebase is up and running.
A place for pics, either of your setup, your vehicle, yourself or anything else!
Apbuild
Got the homebase set up yesterday.
I took the 1/2 wave down from the chimney some time ago due to several different reasons so I thought I would experiment after reading Jason's post about mobile antennas versus homebase antennas.
I tried to mount a Thunderpole orbitor on a small piece of flat metal plate, approx 12" x 12", on the horizontal binder timber in my loft. Once connected up, it worked to a degree but the swr was a little to high for my liking.
I then noticed an old galvanised metal water tank that has been sitting in my loft since I changed it for a plastic one several years ago. It is about three foot by three foot in size. I drilled a hole in the side of it, mounted the Orbitor on it and then went back down to swr again.
Got the swr down nice and low so I hooked up all of the gear and started a call out.
I was getting out to Oxford and Abingdon with really good reports on my modulation. Thats approx 10 miles on a springer in the loft! (With a little help)! And I was receiving all of the Oxford braekers really clear!
Reason for this post:
If you are prepared to experiment and put in a little time and initiative, you can get results. If you are prepared to pay a bit more money on your gear you can get better results. I may even go to the lengths of trying my Wilson 1000 on the metal tank in the loft just to see if there is any improvement.
I am glad I didn't chuck that tank out.
Cheers,
Rob.
Power supply and radio.
You got Eclipse coming at you!!!!!
I'd rather be mud pluggin, fishin', or shootin! (Or on my CB Radio)!
hotmetal1000
Give us a picture of the tank and antenna will ya????? :D
Apbuild
Give me a while, I will have to get the step ladders in to get into the loft!!!!!!
Be right back.
Rob.
Apbuild
Here you go mate!
Two piccys of the tank and springer and one of the small plate that I tried but had no joy with.
If you are going to try this, my advice is to get as big a groundplane as you can.
Rob.
hotmetal1000
That's awesome buddy, thanks for taking the time to get a picture of it.
a little gray matter and good results well thought out now get our sponsers to sell water tanks
:D :D :D :D :D :D :D :D
Apbuild
Rusty old ones with holes in them for ventilation?
As I run a construction firm I will be salvaging any that I may come across in the future.
Keep an eye out on **** chaps!
LOL!
Rob.
fatfinger
Official CB Legend!!!
must be the ballcock that gets the swr down nice and low :lol: :lol: :lol:
nice work mate
and good pixs
jason
i was going to have a little experiment of my own ,, but you just saved me some time :D :D :D
i am going to try the sirio 4000 on the roof of my house against the a99 so i will let you all know soon , i will put a fiver down that the sirio 4000 performs as good as the a99,,
the DJ (discjokey)
if i can help ,i will.
jdo330
Hi Rob,
Great write-up Rob, very interesting indeed.
So, in terms of performance vs the silver rod. Which ones best?
ATB, Jon.
Apbuild
Can't say at the moment mate because I didn't really try the 1/2 wave for very long.
All I will say is that the missus didn't appreciate the howl down the chimney to the living room from the 1/2 wave so I had to think of something else.
The springer seems to work well but I am now intrigued to try out a Wilson 1000 in the loft because the Wilson on my 4x4 works superb.
Maybe post results later.
10-10 mate.
Rob.
jason
nice power supply,, i use the same , 8) 8)
you cant beat having those quick connections on the front for odd jobs
the DJ (discjokey)
fatfinger
would love to no the results of a wilson 1000 in a loft
might even give this one a go myself :lol:
Apbuild
Have ordered the so239 DV mount with and will post results when fitted.
Rob.
jdo330
Rob,
How are you connecting it all up, are you runing one long coax and putting the required connectors on the ends or have you got a join somewhere :?
Also, would love to know what you think of the performance now you have had it up there a couple of days. Itching to do the same :)
ATB, Jon.
