I took the 1/2 wave down from the chimney some time ago due to several different reasons so I thought I would experiment after reading Jason's post about mobile antennas versus homebase antennas.
I tried to mount a Thunderpole orbitor on a small piece of flat metal plate, approx 12" x 12", on the horizontal binder timber in my loft. Once connected up, it worked to a degree but the swr was a little to high for my liking.
I then noticed an old galvanised metal water tank that has been sitting in my loft since I changed it for a plastic one several years ago. It is about three foot by three foot in size. I drilled a hole in the side of it, mounted the Orbitor on it and then went back down to swr again.
Got the swr down nice and low so I hooked up all of the gear and started a call out.
I was getting out to Oxford and Abingdon with really good reports on my modulation. Thats approx 10 miles on a springer in the loft! (With a little help)! And I was receiving all of the Oxford braekers really clear!
Reason for this post:
If you are prepared to experiment and put in a little time and initiative, you can get results. If you are prepared to pay a bit more money on your gear you can get better results. I may even go to the lengths of trying my Wilson 1000 on the metal tank in the loft just to see if there is any improvement.
I am glad I didn't chuck that tank out.
Cheers,
Rob.
Power supply and radio.
