Jon,
At the moment I have the springer on the tank. The coax is one length, down into my office with a DV elbow at the bottom of the antenna and a pl259 into the back of the rig/power. The coax is a lead from Thunderpole and is 10 metres in length. Obviously, I had to fit the DV end myself at home which was pretty easy if you have a steady hand and a soldering iron.
The so239 I have coming should accept the DV socket.
I will get a rig check from a fellow breaker I know in Oxford with the springer, then run up into the loft and change to the Wilson, swr in the office and then get a follow up rig check from the same breaker. Distance of this contact is around 12 miles.
Will report on the findings later.
Rob.
Homebase is up and running.
Here are the results from the Swedish jury....................
Got a signal check this evening from a breaker in Abingdon, Oxon. That's ten miles from me. I had left the springer in the loft and the report was that I was giving 4 pounds of signal with significant background noise. (I seem to pick up a fair bit of interference in the evening. I guess it's all the people at home with appliances and tv's running etc).
I then popped up into the loft and fitted the Wilson 1000 to the tank. See piccy below.
SWR in the office once I had climbed down was 1:1.5. That's fine with me!
The second report from my fellow breaker (he had kindly agreed to stay on channel and wait for me to change over), was that I was giving 6 pounds of signal with significant reduction in background noise.
REMEMBER THIS WAS TESTED WITH THE SAME RIG SET UP AT THE SAME POWER!
The results are plain to see. I would however like to get the 1/2 wave or even an antron back up on the chimnney. I have been advised to tape off the ends of the mounting pole to stop that 'Blow over the Bottle-top' hum that you can get in the wind.
Hope you enjoyed the little xperiment as much as I have.
Cheers,
Rob.
10-10
Cheers,
Rob.
10-10
You got Eclipse coming at you!!!!!
I'd rather be mud pluggin, fishin', or shootin! (Or on my CB Radio)!
Jason,jason wrote:very good ,
from now on we shall call it ''rob's law''
the best mobile in the loft is as good as a budget homebase on the chimney 8)
I still think that for long distance and clarity, you cannot beat the Antron 99, and for a tenner cheaper than the Wilson, I will be investing in one soon methinks.
It will be chimney mounted with the mount pole ends sealed up to erradicate the wind howl that I experienced before with the 1/2 wave installation.
I will report on the performance once installed and up and running.
Rob.
