needle pulses
stevie_a
Why would the signal needle pulses up and down with white noise from the speaker at the same rate
but if you put your hand on the Arial it stops and when you let go it starts again??.. :x
Sounds like interference coming from somewhere...
Is it in a vehicle? Do you have your engine running?
YUP DEFINATELY souinds like altinator interferance when you put your hand on the antenna it kills the incoming signal
stevie_a
Yes it is in the car but it happens even when the engine is off and keys are out ( unit is powered from the battery.)
Still sounds like interference, not from the alternator but coming from somewhere. Could be other electronics in the car that arent killed by ignition switch.
Or maybe coming from somewhere else? Have you tested with car parked in different places?
have you an incar charger for a phone
:D :D :D :D :D :D :D :D
stevie_a
• It is a Triumph TR7 so no fancy electronics.. :lol:
• Yes I have tried it in a different place.. :?
• No in car charger for a phone... :?
can you find a pattern in the white noise try it late at night when the skip has died off and see if you still get the same effect at the same level
tranexneil
Check the battery, ie: connect the radio to a different car battery in the same vehicle if that solves it you have a High Resistance battery ! Ive seen similar issues on PMR equipment, Can also be caused by a corroded fuse / Holder.
Regards
Neil
stevie_a
Well I have been told that the needle pulse is due to my clock and the rig being in the glove box next to the fuses
so I am going to move everything today and also swr up the Arial with my new meter that I have just purchased from the flee-bay.
stevie_a
ok
I now have moved the rig to the rear shelf and no pulse perfect.
Attached the swr meter and low and behold swr way out sitting at 5.5 .. :shock:
Can get it down to 3.5 to 4.0 but can’t get it any lower... :cry:
You know what I am going to ask don’t you... :wink:
How the hell do I get it lower … :evil:
if its higher on top channels the cut the whip
:D :D :D :D :D :D :D :D :D
stevie_a
Yes the reading is higher in the higher channels.
Do you mean cut the antenna if so how much do you take off ?
golden rule that which you cut off you cant stick back on try 1/4" first and see how mutch is drops
stevie_a
Ok tomorrow night I intend to go back out to the car to swr up the Arial
So if it is reading high at channel 40 and low at channel 1
I cut the antenna down to get a better swr
YES ?
.. :roll:
